Specifying document georeferencing
Command |
Path |
Georeferencing |
File > Document Settings |
The goal of working with a georeferenced drawing in Vectorworks is to align the drawing’s internal origin, and therefore its geometry, with a specific location on Earth. Georeferencing options are complex; what works for architectural workflows may not be suitable for a planning workflow. Additionally, different regions of the Earth have different geographical requirements. Since the earth is not a perfect sphere, it is not a straightforward process to correlate the Earth’s three-dimensional surface with a two-dimensional map. Coordinate systems use mathematical formulas to translate the shape of the earth onto a 2D page. Because the translation loses data, different coordinate systems are preferable for different regions of the globe.
A proper coordinate system has a big impact on distance measurements. A distance in the drawing and the same distance on the map will match, more or less, depending on the selected coordinate system. The closer the match to the region being worked upon, the closer and more accurate the measurements and dimensions are.
When georeferencing is enabled, each design layer saves information that describes the mapping of that layer’s Cartesian coordinate system onto a geographical coordinate system of latitude and longitude or easting and northing. The origin offset determines how the geographical coordinate system relates to the internal origin (the center of the drawing in the Vectorworks file); this offset can be adjusted at the document level or at the layer level.
There are three methods to set up the document’s georeferencing: the Georeferencing command, the Geolocate tool and the Survey Point tool. While the Georeferencing dialog box always specifies the coordinates for the internal origin, the Survey Point tool sets the georeferencing through any point on the design layer where you have known coordinates (usually from a survey with coordinates or from determined project coordinates). The Geolocate tool provides a visual method of selecting where to place your project; this is a good method if you don’t have exact coordinates but can take advantage of the displayed map's background.
The Georeferencing parameters set up the document’s georeferencing. Normally, all or most design layers have the same georeferencing information as that of the document; layers without georeferencing enabled automatically assume the document georeferencing settings. A georeferenced layer moves with changing geolocation (essentially, remaining on the globe), while a non-georeferenced layer always remains around the internal origin. After the document georeferencing is set, you can enable and customize a layer’s individual georeferencing settings differently, but this is rarely needed.
When importing a shapefile, the document georeferencing can be automatically set to match the coordinate system of the imported file.
To set georeferencing for the document:
Select the command.
The Document Georeferencing dialog box opens.
Parameter |
Description |
Select a Coordinate System |
Select one of the Coordinate systems based on the drawing’s geographic location and the extents of the drawing; additional parameters that are required to map to the selected coordinate system display in the area below |
Use WGS84/Pseudo-Mercator for worldwide use |
This global coordinate system is good for general purposes, but because it displays the entire globe, distortion can reduce accuracy when matching the Vectorworks distances and the map distances. If possible, select a more regionally-specific coordinate system. |
Uses the International Association of Oil and Gas Producer's EPSG Geodetic Parameter Dataset code or Coordinate Reference System (CRS) name to specify the coordinate system. Click EPSG/CRS Lookup to select the desired reference system from the EPSG/CRS Lookup dialog box. Click Hide deprecated CRSs to only view currently applicable systems. The selected system displays in the Document Georeferencing dialog box. Enter text in the Filter field to filter the list. |
Use a projection ( .prj, .proj4, .xml) file on your computer |
If you have a specific projection file for the georeferencing coordinate system, click Browse to select it |
Use a common coordinate system or enter Well Known Text (WKT) |
Select one of the Vectorworks default Coordinate systems that is supported by GDAL (Geospatial Data Abstraction Library), or select to use the WKT markup language. From the Coordinate System list, enter one or more terms in the search box to filter the list. Depending upon the selection, additional parameters display in the area below. |
Displays a description of the coordinate system data. You can edit the coordinate system text and save it for future use. Click Save or Delete to add/remove a custom item in the Coordinate System list; specify a unique CRS Name when saving if you do not want to replace the existing data. Click EPSG/CRS Lookup to select the desired reference system from the EPSG/CRS Lookup dialog box. Click Hide deprecated CRSs to only view currently applicable systems. Enter text in the Filter field to filter the list. |
Ellipsoid |
Select the appropriate reference ellipsoid used to create the coordinate system |
UTM Grid Zone/Hemisphere |
For the Universal Transverse Mercator (UTM) coordinate system, select the UTM grid zone and UTM hemisphere that apply to this drawing |
State/Zone |
For a State Plane Coordinate System (NAD83 or NAD27), select the state and zone that apply to this drawing |
Center Latitude/Longitude |
Specify the latitude and longitude of the center of the selected coordinate system |
Scale |
For the Transverse Mercator coordinate system, specify the scale factor along the central longitude; for the Stereographic coordinate system, specify the scale factor at the central point |
Standard Parallel 1/2 |
For the Lambert Conformal Conic coordinate system, enter the two standard parallels to use for the coordinate system |
Location and orientation of the internal origin |
These options affect the way the Vectorworks drawing (internal origin) relates to the geographical location. You can offset the location of the georeferenced data so that it matches the way that the coordinate system relates to the drawing’s internal origin. Normally, these options should be enabled and set to a location close to the site. This ensures that your drawing work on the site is within the double-precision limits required for accurate mathematical calculations and operations in Vectorworks. When this option is manually enabled, the Onscreen View Control can display a compass ring based on the Angle to True North value; see Onscreen View Control appearance. |
Specify geographical coordinates / Specify geographical (WGS-84) coordinates |
Offsets the coordinates of the internal origin according to geographical or geographical (WGS-84) coordinates |
Specifies the latitude and longitude at the document origin (0,0); enter decimal degrees, or degrees/minutes/seconds (for example, 39.18, 39° 10’ 32”, or 39d 10m 32s) preceded by a minus (-) sign when appropriate |
Specify Cartesian coordinates |
Offsets the coordinates of the internal origin according to Cartesian coordinates, Easting (X) and Northing (Y); enter the coordinates in meters or feet, according to the selected coordinate system. Precision values are always set to eight positions past the decimal point, regardless of the document unit settings. |
Angle to True North |
Specifies which direction is north from the document origin; use an azimuth degree measurement (0° is along the Y axis, 90° is along the positive X axis) |
Reset |
Discards any edits made and returns all fields to their former values |
If you changed the coordinate system, the Geographic Transformation Mode dialog box opens. Specify the action to take for any existing objects.
Parameter |
Description |
Transformation mode |
Select the appropriate option for transforming the geometry of objects on the layer if the layer’s coordinate system type changes: Do not transform the objects: Objects are not transformed; the object location may change, so this option is best for new files without any objects or for objects that do not represent geographical items. Transform all objects individually: Best for projecting geographic data, such as municipal boundaries, roads, rivers, and locations on a map; this option moves and scales all objects on georeferenced layers. If you have made any manual adjustments to the Latitude/Longitude offset or the North angle, select this option. Move and rotate all objects as a group: Best for projecting non-geographic drawing objects, such as architectural plans; this option moves and rotates all objects on georeferenced layers, but does not change their shape. |
Transform images to match layer’s coordinate system (document georeferencing required) |
For imported georeferenced images, ensures that the image pixels are at the correct latitude and longitude to match the layer’s coordinate system; when selected, image objects are also transformed if the Transformation mode is changed |
Enable georeferencing for each design layer that requires it, as described in Specifying design layer georeferencing.
